I’m trying to use Litchi (v4.26.9-a) on the RC Plus controller and the DJI M350. When I open the app, it shows P-mode at the top of the screen which seems correct. However, when I attempt to start a mission, it prompts me to switch the flight mode to F. But when I switch to F-mode, it then says that it can’t operate in that mode.
Here you can read what drones are compatible with Litchi:
I don’t see the DJI M350 on that list, however, the DJI M300 is not there either and with that drone, Litchi works just fine, so, I had to give it a try and encourage the developers to fix this issue, Litchi gives me total control as far as where to start, stop, and the exact path that I need the drone to follow. It would be really appreciated if we can get this fixed.
Litchi Pilot should work with M350
It prompts me to switch the flight mode to F. But when I switch to F-mode, it then says that it can’t operate in that mode.
You need to use a different app [OPEN BETA] Litchi Pilot
Awesome, thanks Vico! This looks promising, I just installed the app on the RC Plus, and of course, it’s raining RN, lol, but I’m seeing my missions listed and I can pick the M350 as well, so, as soon as I can take off I will post back.
Were you able to take off?
