Hello, After using a WP mission create using the BETA Hub Mission planner, I sufferred a Flyaway of my 3 year old Air 3. THIS IS NOT A LITCHI ISSUE.
After providing DJI with a full copy of my data: (\Android\data\dji.go.v5\files\FlightRecord) they confirmed for me that it is, in fact, a manufacture defect. They came back to me with the following results:Good day Gary,
This email is to inform you of the flight data results for your recent repair case.
Results:
confirmed
FLY(146)
1. The unit was in APAS mode and took off with a good GPS signal.
2. At t=10:28s, relative height h=1032.1m, distance to home point d=3852.3m, flight log cut off, due to aircraft disconnecting from RC.
3. User commanded PITCH forward and ROLL right, prior to flight log cutting off.
4. The unit was moving forward, prior to flight log cutting off.
5. The unit was not prompted to return home when it should have. The unit did not receive any warnings or errors during flight incident.
6. Unable to determine with APP records.
7. Distance: If the drone is flown beyond its maximum transmission range, it may lose its signal with the controller or ground station.
8. Obstructions: Physical obstructions, such as buildings, trees, or other structures, can block or weaken the drone’s transmission signal.
9. To minimize the risk of losing the transmission signal, it is important to maintain line-of-sight communication with the drone and avoid flying in areas with obstructions. In reference to the provided video, the flight environment served as an obstruction between the aircraft and Goggles/RC, causing a disconnect between the two as the unit began to nose-dive.
Incident date: 05-01-2026
Incident GPS location: 33.4186253, -111.4018073
Activation date: 08-26-2023
They are expediting a new Air 3, a New Battery, and new props.
I am sharing this in case anyone else experiences a lost aircraft. I did NOT have any Refresh warranties or insurance. Actually, I was quite surprised. It is worth contacting DJI Support even if you are not sure they will replace it for free.
