Hi there.
Who knows may be: why I cant connect to RC (Phantom 4 pro or Mavic 2 Pro) using my iPad mini 6.
I’m trying to use USB Type-C wire.
Who fix this issue?
Try a different cable …
I’ve tried three different cables including original DJI
All the time the same.
Hi,
I have the same problem than jaggaboom182.
why I cant connect to RC (Phantom 4 pro) using my iPad mini 6.
Who fixed the issue ?
Thank’s
same problem with a spark, should be simple. but not!
Check that you have Location services (i.e. GPS) enabled on the iPad. That was the problem I had with another tablet.
Litchi + controller is not binding to the drone. When I press the button on my Mavic 2 nothing changes. In on pixel 6. The whole reason why I bought litchi is that the DJI app does not work on pixel 6. GPS works as I can see the map in the litchi app on the phone.
