Can anyone help me? I couldn’t make the flight because of this message! I prepare it in Qgroud then use the lychee
3D distance invalidates route point 51e 51 the valid range is (0,6,1999) m
In order to help diagnose the mission, you’ll need to share it.
This makes no sense, probably the actual message you get is:
“Invalid 3D distance between waypoint 51 and 52, valid range is (0.6,1999)m”
It means you have 2 waypoints in your mission that are either
-Too close to each other (closer than 0.6m)
or
-Too far from each other (farther than 1999m)
Check the coördinates and altitude of waypoints 51 & 52.
