Curves grayed out
Hello,
I imported a simple KML with 4 points. Some of the turns or points have curves automatically, which I like, but some of the points did not create a curved turn and it won’t let me set a curve for that point in the settings.
Any ideas? Thank you!
For curved turns to appear, you must:
  1. In “Settings” path mode must be set to curved turns.
  2. In the waypoint dialog, “curve size” must have a non-zero value.
Thank you for the response! Unfortunately, I had already seen and checked those things, but alas…
Some ot the corners have curves. The ones that don’t won’t allow me to move the slider or input a value for a curve radius.
Something is not right.
Only 2 points (waypoints) in a 4 points mission can have curves.
The first & last waypoint can’t have a curve because a curve needs 3 consecutive waypoints.
Ah, ok. Thank you, That’s good to know. I guess if I want a rectangular path I can at more points manually to achieve that.
Thank you for clearing that up!
