Convert Geo Tiff to ASC II file for Dem Model import
I want to map a parcel of hunting land on a property with steep terrain slope; i dont think 30 meter DEM will deliver elevation updates soon enough to deliver a safe mapping mission
Is anybody willing to give me a step by step guide how to convert a 1 meter USGS Dem tiff file convert to ASC II grid that will work in Litchi
What is max file size Litchi will accept with DEM file import
i am not good with scripts and command line commands
Qgis method ?? I have played around with a few attempts but the progress loader in litchi just spins forever and nothing happens
I believe I have figured out how to add a 10 meter DEM to my flight mission
The dem seems to load smoothly as shown by the progress indicator when loading
once loading has completed the screen turns a white grey; if I scroll / zoom inward ward on the world map I am able to get back to my mapping mission route
is this white/grey screen senario normal or am I experiencing an error?
Thanks for any help you may offer!
After a successful import of a DEM, you should see a transparent blue area where the DEM is located. Example below.
Check this thread for instruction on how to produce the type of file the Hub expects: Using a DEM - I cannot get this to work - #4 by vico
Thank you! Much appreciated for your assistance
For anyone that wants to import elevation Dems / I have been taught how to do this in a simple and easy method using the free QGIS GUI. no command line converting
if you are interested; I will give you access to a screen recording video of the process
When importing custom elevation files
I understand gps coirdinstes must be set to WGS 84 and the file format must be ASC II grip
Is there a restriction for the file size import?
Not really, the file is imported locally in your own browser, it is not uploaded to any server.
Thank you! Most helpful
