Can't find a way to adjust individual waypoint headings
Where is the ability to individually adjust waypoint headings? The older version had a slider to adjust the orientation.
You need to go to the flight global/main settings and select Head Mode = Custom. Then you can adjust the direction the camera is pointing.
Unfortunately it also means you will need to manually adjust the heading for all the waypoints.
