Cannot set Go Home Altitude or Maximum Altitude
I cannot set the Go Home Altitude or the Maximum Altitude. Tapping those boxes does nothing, both are blank.
Tested other numeric boxes and the number pad pops up so the system works.
Been using Litchi for a while, far better than the default DJI app. Running latest v4.28.0-g on Android with Mini2.
Are you connected to the drone?
Yes, and tried without drone and controller. Also, it is useable as is, just have to be aware of unknown Go Home altitude - or is there a default?
Without the drone connected the “Go Home” altitude value should be displayed as “N/A”. With the drone connected it should display the height.
Since the go home altitude value is stored in the drone, you should be able to see it and set it with the DJI app too. Setting it in either app will store the value in the drone and should make that value visible in either app.
That makes sense. If the drone loses signal and is set to return to home on LOS, that altitude had better be stored on the drone.
After updating the never used DJI app, it shows the RTH and max altitudes. But the plot thickens, now Litchi does too, whereas before they were blank and no keyboard when tapped. Chalk it up to one of life’s little mysteries. Thanks for the help.
How do you set the RTH in the Litchi App? Is the default the RTH stored in the DJI App?
To set the RTH height, go to the settings by selecting the gear icon in the upper right corner of the Litchi app.
There isn’t really a default. The RTH height is stored in the drone and is “remembered” from one flying session to the next.
