Every time I login, as an example I have to change from Metric to Imperial. Can setting be saved?
I have the same issue but It has been this way forever. I’m guessing since Metric system is used by the majority of the world it’s set up this way.
Welcome to the forum.
Please clarify what you are logging into. Are you referring to one of the Litchi apps or perhaps Litchi’s Mission Hub.
If you are referring to Litchi’s new Mission Hub, it should remember the login state from one session to the next so that you do not have to continuously log in.
Litchi’s Mission Hub settings are stored in the local storage memory of your browser. If the Mission Hub settings are not being remembered from one session to the next, it may mean that you are clearing your browsers memory when your browser is closed. If you want these settings to persist from one session to the next, you will not want to clear the browser’s memory when closing your browser.
That makes sense. I’ll give it a try. Thanks
My apologies. I misread it as you meant logging in for first time since there should be no reason to log in every time. Anyway, It still will be set to metric when logging in for the first time, using a different device and/or browser for first time and obviously after clearing browser junk as Wes stated. I clear all my browser junk often but it only takes me about 2 seconds to switch to imperial. Enjoy.
