I fly a lot of waypoint missions from my back yard. Because of the terrain and hazards, natural and man made, in the vicinity of my launch/recovery location, I defined 3 waypoints to use when leaving on the mission and when returning from the mission.
I designed a short mission to take pictures at each waypoint. I used the action option for default panorama at each waypoint. I edited the default rotate headings to start from 0° (why anyone would want to start from 180° is beyond me
The first time I flew the mission, the aircraft went where I expected it to go and rotated as I expected it to but the camera didn’t take pictures when I wanted it to.
When I compared to images exif data to the AirData csv file, I determined the pictures were taken at 10 second intervals. Before you say too much, I had the photo capture interval in the mission hub settings disabled.
I finally figured out the problem was within the Capture Mode settings on the controller. Sometime in the past, I had set the type as Interval with a 10 second setting as opposed to using a type of Single.
I changed the Capture Mode setting type to Single and flew the mission again. In general, everything worked as expected and planned.
It appears as if the Capture Mode on the controller is anything but Single, the camera actions defined in the mission are ignored.
I know this forum has discussed the AutoRecord setting and how it interferes with waypoint missions but I haven’t found any reference to Interval being selected. Nor is there any mention in the Help files.
Not really an issue for me, but I thought I would share my new knowledge with the group.
I have developed a workflow, using Exif Pilot and a homebrew Excel program, which allows me to quickly (15 minutes, more or less) to print a report with thumbnails of each photo and the associated location, timedate stamp and bearing from the aircraft.
This brings me to my questions.
Why would the compass heading and the gimbal heading be different?
Example: the waypoint action is to rotate the aircraft to 52°. The data row in the AirData file representing when the photo was taken, shows the compass_heading as 51.6° and the gimbal_heading as 46°. -
Which heading truly represents the reference from the aircraft location to what the camera saw?
With the exception of the second image in the pano series, all the changes are 51 to 53 degrees. The change from the first to the second image is 46 degrees.
The value differences are relatively consistent for all three waypoints.
Thanks visiting and ya’ll stay safe, now, hear!
