Se puede hacer un plan de vuelo grande, en el que cuando se termine la batería el dron baje para cambiar la batería y que se pueda continuar en el punto donde se agotó la bateria y así las veces necesarias hasta que termine el plan de vuelo?
NO.
When the battery runs low, the build in DJI Low Battery RTH will be initiated, as explained in the user manual of your drone.
I think there may be a misunderstanding due to translation. Yes. When the aircraft hits low battery it will RTH and land at the recorded home point. Power down the drone and insert new battery and power back up. Once it indicates ready to go you can resume the mission and it will fly back to the last location where it triggered the RTH. It will continue the mission until completion or another battery swap is needed. It will even continue capturing any Photos or continue capturing Video without missing a lick. This can be done with several battery swaps. This is how all third party apps work to include Dronelink which is what I have used about 99.9% of the time over the past 5 years. Litchi works the same and you should have no issues with longer flights.
