Area Mapping 2D vs 3D
New to Litchi Hub and just amazed at what it brings to flight planning. My question - I assumed the 3D modeling was for flight planning only yet when creating an area mapping route and toggle between 2D and 3D the flight path changes. This makes me assume the output is different. If you use something like Web ODM and you area map using Litchi 3D do you have the ability to create a 3D file? Thx
Absolutely!
The 3D option takes images from different angles, which is necessary for software like ODM to create better models.
Are there any specific parameters that need to be adjusted in WebODM to generate a 3D map?
You can generate a 3D model from a grid mission.
This screenshot is from a grid mission with an added low-altitude orbit to capture more details. You can still see holes in the model.
So, should I run a “Mapping mode” mission with the 3D option enabled? I’m also going to try adding 4 oblique passes and activating the “Nadir Pass” option. For the Capture Mode, I’ve selected “auto.”
You should go to the WebODM website for their software support. Click on Docs at the top and it will take you to their documentation which should help. There are way too many settings in their software and it will depend on many factors. The default settings should work well so I’d try processing a small map to see how it looks first. If there are any issues then the WebODM documentation should help. There are also community forums. Enjoy.
More photo captures doesn’t necessarily mean better final results. Capturing many more than needed will result in more hours of processing especially if it’s a large area. Even if it’s a newer powerful device it can take about 5 to 20 hours or more to process the Ortho on a large map. I’d set it to 3D model with just the 2 passes on a small map like about 5 acres or less. Then use WebODM to process the Ortho and see how long it takes to process and what the results look like.
The difference between a 2D mission and 3D mission is the camera tilt angle.
2D captures -90° angles. 3D captures at -65° giving more of the side view.
You can see the difference if you run the Simulation.
Okay, thanks for the advice; indeed, reducing the number of oblique passes from 4 to 2 significantly cuts down on the number of shots. I could use the time and resources “gained” this way to lower the AGL altitude—would 40 meters be appropriate, or is an even lower altitude advisable?
You can fly at any altitude. Just remember. The lower in altitude you fly the slower the speed needs to be especially when using a drone which has no mechanical shutter. If you run the mission too fast you may get motion blur and the photos won’t be any good. In general, the higher you fly the faster the speed can be and the lower you fly the slower the speed needs to be. At 40m I’d try about 10 mph, 16 kph and test a small mapping mission to see if the images are clear so when their processed they will be sharp/ clear. There is a lot of information on the internet which can recommend at what altitude and speed to get great results. Enjoy.
This is 3dscenery.png the final result (top right) I’ve managed to achieve, as integrated into X-Plane following a processing step in Blender (importing it into an X-Plane scenery environment was my ultimate goal). I’m already quite satisfied, but is there anything I can tweak in the flight parameters to get more detail? For instance, could I lower the AGL altitude to 30 meters and perform 4 oblique passes? Or are there other approaches?
