Hi,
For my Mini SE? In the city after about 500 - 700m I experience weak signal or signal loss. Will Yagi antenna booster help?
thanks
Gregory
- Yagi antennae are physically different for 2.4GHz and 5.8GHz.
- So you have to set ‘Channel Mode’ under ‘Transmission’ in the DJI Fly app to ‘Manual’ and choose the correct channel for the type of Yagi antenna you want to use. Then switch to Litchi.
I used them with the Mini-1 but was dissapointed with the result.
YAGI antennas work very well (it’s simple physics) however they are highly directional. This is the reason that you get different opinions as to their effectiveness and some people see a reduction in range.
