Android 16 has killed my Litchi
Howdy All.. I have a Samsung Galaxy A15 phone. Since the last update of android system back in December 2025, my Litchi that worked fine, stopped working. I have ended up starting from scratch as to re-buying Litch app. Its version 5.0 if I remember right, for right now. Downloaded the newer APK from Litchi website here and installed on phone. My stock Air 2S controller and bird hookup together and control each other fine. But.. the video from the drone camera does not come through the Litchi app, and the readouts for GPS and other readouts you can normally see on app. The Litchi app is still not working right on my phone! It just sits there on phone with all the logos and stuff, but does not do anything else. Needless to say, it is pi$$ing me off! Can not see what I am doing through the app. That wont work for good video shooting. Has anyone else had this recent problem with their Android working right with Litchi now? Everything between the controller and the bird work fine.. just cant see anything with it. Have never crashed my drone either. Thanks for any help :slight_smile:
Do you also have DJI Fly on that phone? If so, do you get a video signal from the Air 2S? Also, if you have DJI Fly on the phone you will need to “Force close” DJI Fly (not just close it) before running the Litchi app.
Hello Wes.. thanks for responding! Yes I do have the DJI Fly app on there, and have it in forced closed like supposed too. I’ll have to set up my drone and controller here at home, and see if even the DJI app will see and do anything. I do know, that when I open the Litchi app, and go to the “General” catagory, and try to do that “sync license” deal, it always says that it fails to sync… wierd. My Litchi has worked fine for the past 2 years on my, the same phone, but has not since the last Android update. Thats why I thought I would just start from scrath with buying the Litchi app again. Litchi is just not hookin up with it. The controller and the drone control and see each other just fine. Litchi does not sync of whatever with it. Frustrated to say the least, Sir. Thank you… :wink: Have big video project I have to do, and hopeing to get started soon as I can, but cant yet..:angry:
Try enabling USB debugging on your A15:
-Go to “Settings” > “About phone”
-Click on “Build number” approx. 7 times to add “Developer options” to the Settings menu
-Go to “Settings” > “Developer options”
-Enable USB debugging
In addition to the de bug procedure, there is an addit8step after using the developer mode on the phone. This effectively “rolls back” the Google update that causes the problem. It’s relatively simple. Worked great on two of my devices that lost the FCC hack on the Drone tweaks app. If you want to try it I can forward links to the procedure. It does not harm the device, even if it fails to correct the issue.
Try the following: After connecting the USB cable to your phone, swipe down from the top of the screen. You will see a USB option; change it to MIDI and it should work. If it doesn’t work, try a different option than “charge,” as the phone is interpreting the radio as a charger.
Hello to everyone! Thank you all so much for your help with me in getting a combo of my phone and the Litchi app hookin up right. It has worked for 2 years, but apparently my phone got an update that was stupid and messed it up. I ended up doing a factory reset on my phone, and reloading everything in to it. YAHOOO its is working right now!!!:slightly_smiling_face: Now I can get back to flyin and all that fun stuff that goes with it :wink: Happy safe flyin out there!!
