Allow user to set a default drone model
We fly two Mavic 2 Pro drones - any chance I can default that so I don’t have to set it manually every single time?
It should already remember the last one you used, so if you always use the same drone, you should not have to reselect it when creating new flights
Well it doesn’t remember the last drone I’ve used.
I import flights created by QGIS plugin, maybe import loses such information?
You will have to do some troubleshooting. The drone model and other persistent data is stored in your browser’s “Session Storage”.
We are not familiar with your workflow. Create a new mission as most others would do to see if your drone type is remembered.
Thank you, so it’s not a functionality online, but a local stored setting.
yeah I have a lot of purge cache and block scripts and other plugins going on.
so I need to give exceptions for your website because such data is stored client-side.
Now I know - thank you
When you import a CSV, it does not set the drone to the last one used, but we’ll fix that in the next update
