Add Setup Waypoints
Flying Magic 4 Pro with RC Pro 2 Controller and planning on litchi hub desktop. Flying waypoints for photogrammetry.
It would be huge to have a selectable feature that would add a “Setup” waypoint to the start of each capture path that would allow the heading of the drone to be in line with the 1st planned capture waypoint AND the gimbal to be rotated to the prescribed angle that matches the capture waypoints.
Currently the first capture in a pass is taken while the drone is still rotating to align with the pass heading causing a lesser quality image and/or if it’s the first image in a flight the gimbal may still be rotating downward to the prescribed angle resulting in a throwaway image.
Please share which mapping settings you are using or share a link to a sample flight so we can test as we may have fixed this already, just not released yet.
Guide to share a flight: [GUIDE] How to Share a Flight or Folder
I have tested your flight and this is something we have been working to fix, and is normally fixed internally, we hope to release this soon.
Regenerate your flight with the latest Hub version released today and it should provide you better results now, let us know if you still have any issues
