360 AEB/HDR Panoramas on Dji Mini 3 pro
Hello
I’m looking to buy the DJI RC Pro controller specifically for use with the Litchi app. My primary goal is to create automated 360° AEB/HDRI panoramas. Can anyone confirm if this setup will work 100% with the Mini 3 Pro and the RC Pro using Litchi?
I don’t need Litchi to stitch anything—I’d prefer a batch of RAW images that I can process later on my PC using PTGui.
Thanks!
Currently Litchi Pilot cannot shoot panoramas. It will be able to at some point
sad to hear that, but thanks for clarification
As an alternative, you may wish to consider my Litchi utilities that will allow you to create a waypoint mission to capture a set of images for a panorama. The resulting waypoint mission can be flown with the Mini 3 Pro. What I don’t know is whether Litchi Pilot will capture AEB/HDR photos when the “Take photo” waypoint action is used.
Thank you for the suggestion. Unfortunately, I can’t confirm if AEB is currently possible with this setup. Until further updates, it looks like I’ll have to do it completely manually.
You can use the Waypoint mode to program your panorama using waypoint actions. If you want to get AEB shots, make sure you select AEB photo mode before you start the flight
