Copying and pasting the coordinates is ok to do. However, the original mission that you shared had all of those waypoints at a height of 45m. Perhaps you forgot to change the height.
Thatâs my goal, smoother videos. Iâm really bad with sticks.
Still, itâs not turning completely -90. I donât know why.
For better videos, Path Mode should be Straight Lines or Curved Turns?
Between waypoints 6 and 7 the gimbal pitch angle should transition from -45 to -90. What does it actually do in the flown mission?
Curved turns with non-zero curve sizes would produce smoother video than straight-line missions.
Maybe because WP6 and WP7 are close and at speed 8.3(m/s) and then to WP8 must go back to -20.
Add another WP under WP7 to try ? or a âstay forâ on WP7
The distance between WP6 and WP7 is roughly 10m. I would think that is enough distance for the gimbal to transition from -45 at WP6 to -90 at WP7. However, an easy test for Rodrigo would be to change that distance and run a test to see if that allows the gimbal to fully rotate to -90. If that does fix it, it would be an easy solution.
I donât think any waypoints should be added at this point. The movements he desires should be possible with the number of waypoints defined. Also, a âStay Forâ action would not be executed (using Litchi) because he is using âCurved Turnsâ.
Very good Patrick. DJI Fly will execute waypoint actions such as a âWait Forâ even though it is flying a curved mission.
Itâs enough but he stay only for a fraction of a second (1st one in video), since he has to transit to -20 going at WP8 (in my case WP4).
