Waypoint on the same vertical axe
Hey, I would like to make a waypoint on a same vertical axe, for exemple shooting someone on the ground and making a sequence going up little by little with the camera 100% down . I want a perfect vertical line . For exemple one firts wayppoint at 5 m altitude then a second one 100 meters .
But I don’t fine the way to put two waypoint precisly on the same vertical axe .
Any solution ?
Yes, there is such a solution!
  1. You create the first point, at a height of 10 meters.
  2. You create a point on the side, and at a height of 100 meters. And then copy the longitude and latitude of the first point to the second!
    And your points will be on the same vertical plane.
