# Use purchased Litchi app without Google service
**URL:** <https://forum.flylitchi.com/t/use-purchased-litchi-app-without-google-service/10852>\
**Category:** Help\
**Created:** [July 14, 2023, 8:30pm UTC](https://forum.flylitchi.com/t/use-purchased-litchi-app-without-google-service/10852 "2023-07-14T20:30:00Z")\
**Posts on this page:** 7\
**Page:** 1
<div class="post-metadata">
**Author:** ![Phil3](https://forum.flylitchi.com/letter_avatar_proxy/v4/letter/p/8e7dd6/32.png) [@Phil3](https://forum.flylitchi.com/u/Phil3)\
**Post date:** [July 14, 2023, 8:30pm UTC](https://forum.flylitchi.com/t/use-purchased-litchi-app-without-google-service/10852/1 "2023-07-14T20:30:00Z")
</div>
Hello everyone, I have the following problem and need your help to find a solution:
At that time, I bought the “Litchi App” via the Google Playstore.
Now I have switched to a mobile phone without Google services and now I don’t know how to use the Litchi app without having to pay again.
I have a Litchi account because I had already bought the Litchi app on my old mobile phone.
Do you have a solution to my problem?
Thanks in advance.
Best regards
Phil
**Author:** ![Sam\_G](https://forum.flylitchi.com/user_avatar/forum.flylitchi.com/sam_g/32/2006_2.png) [@Sam\_G](https://forum.flylitchi.com/u/Sam_G)\
**Post date:** [July 14, 2023, 8:34pm UTC](https://forum.flylitchi.com/t/use-purchased-litchi-app-without-google-service/10852/2 "2023-07-14T20:34:49Z")
</div>
@Phil3 ,
You didnt specify which type of phone you started using now, but here the official info from the Litchi FAQ page of the User Guide.
#### 10. I purchased the app on one device, can I install it on other devices?
If that doesnt answer your question, provide more info.
**Post date:** [July 14, 2023, 8:42pm UTC](https://forum.flylitchi.com/t/use-purchased-litchi-app-without-google-service/10852/3 "2023-07-14T20:42:19Z")
</div>
Thanks for the fast response 😉
I now use a Huawei P40 Pro.
Since I still had Google services on my old mobile phone (Huawei P20 Pro) and bought it there in the Playstore, this will no longer work with my Huawei P40 Pro without Google services if I understand the answer correctly?
**Post date:** [July 14, 2023, 8:50pm UTC](https://forum.flylitchi.com/t/use-purchased-litchi-app-without-google-service/10852/4 "2023-07-14T20:50:36Z")
</div>
Both phones use Google Play to download apps, dont they?
It could be an issue of Login/password changes that you used on your old phone vs your new phone.
**Post date:** [July 14, 2023, 8:55pm UTC](https://forum.flylitchi.com/t/use-purchased-litchi-app-without-google-service/10852/5 "2023-07-14T20:55:11Z")
</div>
No, unfortunately the Huawei P40 Pro no longer supports Google services and therefore no Google Play. The Huawei P40 Pro uses the Huawei AppGallery to download the apps.
**Post date:** [July 14, 2023, 9:07pm UTC](https://forum.flylitchi.com/t/use-purchased-litchi-app-without-google-service/10852/6 "2023-07-14T21:07:12Z")
</div>
Look at this thread. In the last post, the user went thru the Amazon App route and installed it.
The downside is, you will have to pay again.
> [@Installing on multiple Android devices](https://forum.flylitchi.com/t/installing-on-multiple-android-devices/4185):
> I was trying to install the app on my Huawei but the device options listed my other phone which is android. Thinking nothing of it carried on installing on my other device which is a Red hydrogen One. This installed fine. However I wanted it on the Huawei and it still won’t let me, it doesn’t list the Huawei as an option… I’m seeing other people with a similar problem and can see if you are changing OS systems you have to purchase again but on Android I believe I should be able to install it on …
**Post date:** [July 14, 2023, 9:39pm UTC](https://forum.flylitchi.com/t/use-purchased-litchi-app-without-google-service/10852/7 "2023-07-14T21:39:47Z")
</div>
Thanks for your help.
