Universal Altitude Over Ground
I have an existing waypoint flight that I have laid out. Is there a way to select ALL waypoints for this mission and set their altitude at a fixed number over ground level at that point? For example, all waypoints should be 100 feet over ground level at that waypoint’s location…?
Yes.
In Waypoint mode, choose Select All (bottom right of the parameters section)
Type in the desired altitude (ex: 100 ft). All waypoints will show the change.
In the Flight section of the mission (clipboard symbol at the top), select Above Ground. All waypoints will be adjusted (altitude text will change from white to yellow).
Got it thanks! I didn’t realize that was a fill-in field.
