Programmed flights
I am flying a Magic Pro. During a Litchi programmed flight the “action” required upon reaching a given waypoint is “rotate aircraft”. When this happens the aircraft rotates the required number of degrees but does so extremely quickly often ruining the effect given by a nice slow flight.
Tried adjusting yaw sensitivity but this only seems to affect joystick control during manual flight. Any suggestions as to how I can slow this rotation speed?
Rotation speed in an action is fixed.
In a mission with curved turns:
If two adjacent waypoints have different altitudes and/or headings and/or gimbal pitch then these values will gradually change as the aircraft flies between those waypoints.
Also:
For Gimbal Pitch changes and Flying Speed Changes to work there MUST be a connection between the AC and RC.
Thanks, looks like I’ll have to drop the rotate aircraft action and rely on interpolate. Pity, to be able to program a nice slow pan into a flight would be handy.
