hi all
on a mavic air 2s, is there a way to pause a waypoint mission, and change a battery and then continue where the mission was paused, especially while taking photos on this mission?
thank you
apologies if this question has been asked
hi all
thank you
@Rory_MacLeod
If you notice the screen when you start a mission, it asks if you want to start from WayPoint # 1.
You can start your mission, then stop it at a certain Waypoint# when your battery is low, fly home and change battery. When you start the mission again, choose the Waypoint# where you stopped, then click start.
thank you so much Sam_G.
is there however an easier less managment needed way. as i would not want the drone re-taking pictures or lets say missing a couple between a line of waypoints. as a line may be very long and many pics may be lost or re-taken.
but thanks for the response anyway
Given the lack of autonomous mission on the Air 2S (I have one), you have to manage a multi-battery mission yourself.
Its better to have the drone re-taking some pictures than to miss some along the way.
You can minimize the impact by ending the mission at a certain point (ex: right after the turn at a Waypoint), then start the mission again at that Waypoint #.
thank you Sam_G. good tip
