Dear developers,
tried mission hub on my laptop and discovered a little issue:
When you click on a waypoint, the window with the waypoint parameters does not fit in the vertical window of the browser (here it is firefox-esr in linux). To get the full parameter window, I have to disable the browser’s menu with pressing F11-key.
The resolution of my laptop is 1440x900, so it is not very big, but should fit either.
However, if you can get this window not smaller, maybe you can add a scrollbar at the side.
Second, a question: I did not find an option, how to create a circle at one waypoint and using the waypoint as POI. Where did I miss it, if any?
Thanks for any hints.
Best regards
Hans
