Today, and for the very first time, I tried the Litchi Pilot app with a waypoint mission I created using the new Litchi Mission Hub, for my rarely-used Mini 3 quadcopter.
Because I hadn’t flown the Mini 3 for a while, I checked to see if the IMU and compass might need calibration, but there was no indication that they did, so I launched the drone. After a few uneventful minutes, I noticed that the camera view, and the map view both showed that the drone had begun to yaw in random fashion both to the left and to the right, deviating about 10 degrees from the flight path as it traveled at 28 mph along the gradual arcing trajectories I drew up for it..
An early tropical rainstorm rumbled a few miles off, but the skies were calm closer to home where the drone was carving gentle wide-radius turns during this test flight, and there was no on-screen warning of high winds as I continued to note the series of abrupt un-commanded yaw motions by the drone as it progressed along the flight path.
Soon I noted something I had never seen before, over thousands of past Litchi waypoint missions flown with various older DJI drones. The Mini 3 began to veer off the flight path by as much as ten feet, before correcting itself and reestablishing itself on the true course, often while yawing noticeably.
I finally hit the RTH button when at a point the Mini 3 embarked on a series of complete 360-degree yawing turns, as though the drone was disoriented. Oddly enough, as the Mini 3 made a beeline back home along the RTH vector line, the yawing motion subsided completely and the drone’s orientation remained in perfect unwavering alignment with the RTH flight path line.
With the storm edging closer, I wrapped up my Litchi Pilot flight tests for today, but I’ll be sure and calibrate both the IMU and compass of this Mini 3 before I launch it on the same test flight waypoint missions tomorrow, to find out if the yawing glitch recurs. .
I decided that those un-commanded yaws were worth mentioning in this beta feedback forum, in case it is a known issue either in general or for the Mini 3 alone.
The Mini 3 has always been the ugly duckling of my DJI drone fleet, due to the fact that it cannot continue waypoint missions after RC signal connectivity is interrupted, and that is why it took me so long to test it with the Litchi Pilot app. Now that I have seen this little wonder can handle complex waypoint missions, however, my interest in the lowly Mini3 has been revived, after owning it for over a year during which I rarely dusted it off for use.
I’d be grateful for any thoughts that can be shared about the causes and possible remedies for the odd yawing motions I observed when I flew this Mini 3 using Litchi Pilot for the first time.
All told, the Litchi Pilot app is a brilliant work of software engineering that I know will become as reliable and precise as the original Litchi app that has brought my drones safely home over hundreds of flights that reached out far beyond the horizon. If it turns out that the yaw motions I described here relate to a previously undetected bug, I’d be pleased if it turns out that I played a small role in narrowing down on that bug so that it could be terminated with extreme prejudice by the Litchi code-meisters.
