Mavic Pro 3 waypoints... any way to transfer the DJI remote waypoints to Litchi?
Hi all,
I have an 8 year shoot for a large client. Every two months for 8 years. I programmed a dozen waypoint flights over the construction area and the goal is to create a semi-time lapse of the site while flying circles over some areas and complex multiple-focus-point paths over other areas. (i.e. every few seconds in the edited video, the landscape updates to show current progress, while the drone is flying a pattern). The goal is to have everything remain exactly in place while only the construction zone seems to update. (Obviously, the trees turning colors, winter, summer, etc change too, I just dont want everything to get out of alignment from what Ive already shot to what I will shoot.
So the problem is, I have already shot for a year, and if I switch over to Litchi, I need the flight paths, altitude, speed, angles, gimbal, etc to EXACTLY match the DJI paths.
Is there a way to do this and if so, will the Litchi take all of the DJI information and fly with exactly the same outcome?
Thanks for reading this far.
Import the flight from DJI Fly into Litchi Hub (https://hub.flylitchi.com/) then you can preview it in 3D to see if it does what you want (it should match what DJI Fly does).
Check the guide here for more info: [GUIDE] How to use Litchi Hub with DJI Fly
Note this guide is for exporting but you can use the Litchi Hub Bridge to import as well using ‘Import from DJI Fly’
