Hello all.
I recently installed FCC DRONE TWEAKS on my DJI RC2.
The problem I want to discuss is that this “HACK” is installed in the “dji.go.v6” package on the controller, but Litchi Hub Bridge sees and synchronizes the “dji.go.v5” package. As a result, new dummy waypoint plans are not visible in the Litchi Hub Bridge.
Has anyone faced and solved this issue?
Is there any way to change the Litchi Hub Bridge sync path?
Salve anch’io ho riscontrato lo stesso problema
Which drone are you using ? Not sure why you want to use the FCC tweak. Many people have done this over the years and it usually gives no noticeable improvement. These drones work so well it’s just not needed. Pilots choice. Enjoy.
dji litio xi con rc2
