Sorry I didn’t provide any details on this. There were two default settings, in particular, which I changed. Under (right click on screen)>>Display Settings>>Graphics>>Movies&TV, I change performance from “Let Windows decide(power savings” to “High Performance (not recommended)”. And under Advanced display, I set the refresh rate to 60 Hz. My second screen is a LD 4K TV which has a 60 Hz. rate. My reason for doing all this is in this thread:
[Mobil Rig for Droning](https://forum.flylitchi.com/t/mobil-rig-for-
droning/13457)
Yes, my target TV has only a 60 Hz. refresh rate, and that why I configured my Mini to record at 4K 30 fps, the fastest rate it will do with 4K.
Yes, I suspected the LG native graphics on board the CPU was struggling a bit, and that’s why I did the experiment. So I think you’re exactly right on this.
I don’t know much about this topic, and I don’t know what the Mini 2 uses. But the TV seems happy with whatever codec it uses.
I down loaded VLC to both of my laptops, and I did not get good results, at least with the out-of-the-box settings. The Movies & TV app still seems to be the best if I’m streaming from a computer. My simplest solution is to simply run the micro SD card directly plugged into the TV in my mobil rig,
Thanks very much for your insights…
