It will not take off. Says there’s a unspecified error.
How do I troubleshoot this?
You should provide more information:
-What Litchi version?
-What type of android device?
-What android version?
-Does the drone take off using the Fly App on the same device?
-What Mode is the drone in (C, N or S)?
-Do you Force-Close Fly before starting Litchi?
-A screenshot with the actual message
Dont think dji released the SDK for Mini 1 as its only wi-fi enabled…
Don’t think, the mini-1 is supported by Litchi since oct. 2021.
-What Litchi version? Current
-What type of android device? Pixel 4 full updates
-What android version? 12
-Does the drone take off using the Fly App on the same device? No, neither Fly or Litch will launch.
-What Mode is the drone in (C, N or S)? I know there are a couple modes…still just using the default.
-Do you Force-Close Fly before starting Litchi? I force closed Litchi finally before I posted this. No Fly and no Itch currently.
-A screenshot with the actual message. I have to pass out but it did work last fall. Tried to get my Oculus Quest 2 to work with it but nope. Finally tried Google Cardboard and it did bloody work! Over the winter bought a much more comfortable “google cardboard” and am now trying to repeat that success.
Compass calibration (no idea if this is a real problem) and takeoff via either app is my current problem.
They claimed it was supported at the time of purchase and it did work. That was late fall and I didn’t try to fly again until now.
If this doesn’t work it’s time to contact DJI.
Maybe you should ask a question not about litchi. Since your drone won’t launch at all.
I was primarily attempting to use Litchi as it can drive a VR headset. After some calibration both native and Litch could take off. I’ll do a proper test tomorrow when there’s light.
The order of turnon between mobile device and the controller made no difference if anyone is interested. If that was the case a programmer needs their balls chopped off and I’m a programmer.
Thanks for the advice.
