Following Trails - Corners
Newbie here - when following a trail what is the best strategy to create a smooth transition around corners? Is it more way points or ? I have been trying different things and not getting a smooth transition from curves to straight and back to curves. Appreciate any tips. Couple examples - the one of left is a 90 degree and the right one is more back and forth - THX!
Hi. I’d like to try and provide an answer. You should zoom in on the map as much as possible and increase the number of waypoints, placing them very close together.
As stated above, more wayoints but make sure to use curved turns. I’ve done many over the years running missions in the Forest area near me. The forest roada run on some missions abouf 3.5 miles with a lot of turns/ curves. Following the roadway works great. Enjoy.
MANY THX! I am not sure if this is possible or if willing to share but I would love to see your actual KMZ file I can load into Litchi. What I would like to see is when making these corner transitions smooth where you point the gimble and how far ahead, etc. Appreciate the input.
DJI Fly KMZ converted mission
Litchi created mission
If these don’t work I’ll try another way.
