Hi everyone,
I’m using Litchi Hub to plan a 3D terrain mapping mission with my DJI Air 3S.
The total estimated flight time is approximately 1 hour and 5 minutes.
When exporting the mission to DJI Fly (KMZ), I select the option “Split into Multiple Flights” and set the maximum flight time to 25 minutes.
Litchi indicates that 3 flights will be exported, but when I download the export, I receive only one KMZ file.
My question is: How does this work in practice when flying the mission?
● Does the single KMZ file contain all 3 separate flight segments?
● Will DJI Fly recognise these as 3 separate missions?
● After completing the first 25-minute flight, can I land, replace the battery and then select and start the second part of the mission?
● Will the third part work in the same way?
I would like to complete the entire 3D mapping mission using multiple batteries without having to plan the route manually again.
Has anyone tested this workflow with a DJI Air 3S?
Thanks in advance for your help!
