Hello Litchi Support Team,
I would like to report an issue that started only after upgrading to a Samsung Galaxy S26 Ultra. My previous Android phone worked correctly with the same drone, controller and Litchi workflow.
Equipment
- Aircraft: DJI Air 2S
- Remote Controller: DJI RC-N1
- Mobile Device: Samsung Galaxy S26 Ultra
- Operating System: Android 16 (One UI 8 - latest available update)
- Litchi Version: 5.0.2G
- DJI Fly: Latest available version
- USB Cable: New high-quality USB-C data cable
Normal workflow
Before every flight I perform a pre-flight check using DJI Fly:
- Connect the phone to the RC-N1 via USB.
- Turn on the RC-N1.
- Turn on the Air 2S.
- Open DJI Fly.
- Verify GPS, Home Point, IMU, compass, batteries, RTH altitude and all flight settings.
- Close DJI Fly.
- Open Litchi.
Issue #1 – Litchi does not connect unless I reconnect the USB cable
After closing DJI Fly and opening Litchi, the application does not recognize the aircraft.
The only way to establish the connection is to:
- Physically disconnect the USB cable from the phone.
- Reconnect the USB cable.
Immediately after reconnecting the USB cable, Litchi detects the aircraft and works normally.
This happens every time.
Is this expected behavior, or should Litchi be able to take control of the DJI SDK connection without reconnecting the USB cable?
Issue #2 – Intermittent “Aircraft not connected to RC” warnings
During today’s flight, Litchi displayed the warning:
The warning appeared multiple times during the same flight.
Important observations:
- Litchi did not crash.
- The aircraft was approximately 1–2 meters away.
- The aircraft was hovering or climbing slowly.
- This was not a long-distance flight.
- The warning disappeared and then appeared again several times.
Additional observations
- DJI Fly has never shown this behavior.
- DJI Fly maintains a completely stable connection.
- The issue only occurs in Litchi.
- The issue started only after changing to the Samsung Galaxy S26 Ultra.
- The USB cable has already been replaced with a new one.
- The RC-N1 and Air 2S firmware are up to date.
- DJI Fly and Litchi are both updated to their latest available versions.
Questions
- Is this a known compatibility issue with Samsung Galaxy S26 Ultra, Android 16 / One UI 8, or the current DJI SDK?
- Is there a recommended procedure to switch from DJI Fly to Litchi without physically reconnecting the USB cable?
- Are there any recommended Android settings (USB, battery optimization, permissions, etc.) for Samsung devices?
- Is this behavior already known and scheduled to be addressed in a future Litchi update?
Thank you very much for your support.
