Continue Simulation from currently selected Waypoint
Is it possible to continue a Simulation from the currently selected Waypoint? For me, it always begins playback from WP #1.
I may be wrong, but I think this is a function of the controller, not the map. I’d love to be able to do this, but I haven’t found a way.
You can drag the slider to the desired waypoint and then start the simulation. This is the way I do it if I changed something in the plan and only want to see the changes that were applied.
Thank you for your reply, Mike_m. I am indeed following the same process. I suggest this change to enhance my workflow. When I edit a waypoint (WP) — for example, to adjust the camera’s pitch or yaw — and then restart the simulation from WP#1, I find myself adjusting the WP slider to advance to the edited WP (or just before it). This often causes me to lose some spatial awareness and focus, which detracts from the fluidity of making quick adjustments and continuing from that point. It can be a bit distracting for me. That’s all.
