Can the DJI Mavic 2 Enterprise Advanced Fly Autonomous Litchi Waypoint Missions?
Now that Mavic 2 Enterprise Advanced thermal camera drones have dropped in price to half their cost when new, I am considering buying one specifically to fly night recon waypoint missions over forest and farmland.
While the DJI Pilot app, which is directly compatible with the Mavic 2 Enterprise Advanced, offers its own waypoint planning feature, I am so used to Litchi that I would prefer to use Litchi Mission Hub instead of DJI Pilot 2 if it turns out that Litchi Mission Hub missions are executable by the M2EA.
Thanks in advance for what I hope will be good news from anyone familiar with the Mavic 2 Enterprise Advanced drone as it relates to this burning Litchi question.
PS. Having typed out this enquiry, I opened the Litchi Mission Hub and noted to my relief that the Mavic 2 Enterprise is fully compatible with Litchi Mission Hub. All the same, I decided not to erase this post, just in case anyone else forgets where this information can be looked up.
Mavic 2 Enterprise Advanced is in the ‘older drones’ category so it’s supported in our older flight app Litchi for DJI Drones, not Litchi Pilot which is for drones released from Mini 3 or newer.
Also note that we don’t have a M2EA so while it’s basic functions are supported, some of its advanced features are not (like thermal features etc).
You can plan flights with Litchi Hub for M2EA that’s not an issue
This clarification clears the fog, and I thank you for this reply, Vico. I now see a workaround in which I can plan my waypoint flights with Litchi Mission Hub, then transfer the KML file to DJI Pilot, which is the native app for the Mavic 2 Enterprise Advanced, where I will access the thermal camera controls that will be vital for those night sorties I hope to launch.
This is not going to work.
Litchi Hub’s DJI Pilot app support is for DJI Pilot 2 only. M2EA uses DJI Pilot 1 which is not supported in Litchi Hub.
The KML Litchi Hub exports is designed for Google Earth use mainly, not for DJI apps.
Ah, I’m glad you explained this. Looks like I might be stuck trying to figure out how to create waypoint missions with DJI Pilot. That said, any Litchi waypoint missions that don’t entail thermal camera operations should still work fine with the Mavic 2 Enterprise Advanced.
I’m just playing with the M2EA Smart Controller. It can import KML files, however max of 99 waypoints allowed so if you create a mapping flight it has too many. Trying to work how to reduce the number of waypoints in flights created in mapping.
The Litchi for DJI Drones APK sold on our website can be installed on the smart controller.
It can handle missions with more than 99 waypoints (it executes the first 99 waypoints, then uploads the next 99 waypoints etc). Signal is required to upload each batch
This is music to my ears, Kevin. So glad to know that KML files with fewer than 99 waypoints can be imported into the M2EA. I use my Mavic 2 Pro for my experiments in mapping, but all my other waypoint flights with fewer than 99 waypoints can be imported and flown autonomously.
I will purchase the APK product you’ve mentioned here as soon as I snag my used M2EA. This is the breakthrough I’ve been hoping to hear about.
I exported a flight from litchi hub online as KML. This was then saved to a memory stick. Once done I plugged the memory stick into the smart controller and I was then able to import into the DJI Pilot app.
A test ‘mapping flight’ created in Litchi Hub had too many waypoints as it creates them automatically. My work round was to let it create the flight, then manually create a waypoint flight with just the end points and turns. I think the mapping option creates a waypoint for every change in altitude when AGL is selected.
