Curious if I can use DIJI Fly to take advantage of all my camera and control settings there while running Litchi for a waypoint mission.
No you can’t.
In fact you have to Force Close any other flying app before you can open another.
Thanks for the response. Yesterday, I opened Litchi while Fly was closed, it picked up the camera view so I opened Fly in the background. Litchi maintained the camera view so I tried to fly a waypoint mission. The mission had 18 waypoints and it flew perfectly through number 9 then lost connection. I’ll try it this evening with Fly remaining closed to see if that is the problem.
Thanks! That was my main objective with running FLY so I’ll take a dive into these settings.
I suggest you give this a read
Flew the same mission last night and again, when it hit way point #9, the gimble started to scan top to bottom repeatedly and it remained in static position. I restarted the way point mission beginning at the next way point and the mission finished perfectly.
I suspect that the POI I had set for that way point was too far. I reset that way point to interpolate and I’ll refly the mission again tonight.
Thanks for all the help. The manual is certainly useful.
