# Cable cam impossible avec Mini 2
**URL:** <https://forum.flylitchi.com/t/cable-cam-impossible-avec-mini-2/1465>\
**Category:** Help\
**Tags:** waypoint\
**Created:** [February 19, 2022, 5:18pm UTC](https://forum.flylitchi.com/t/cable-cam-impossible-avec-mini-2/1465 "2022-02-19T17:18:55Z")\
**Posts on this page:** 1\
**Showing post:** 16
<div class="post-metadata">
**Author:** ![TriBar](https://forum.flylitchi.com/user_avatar/forum.flylitchi.com/tribar/32/99_2.png) [@TriBar](https://forum.flylitchi.com/u/TriBar)\
**Post date:** [September 26, 2022, 8:33pm UTC](https://forum.flylitchi.com/t/cable-cam-impossible-avec-mini-2/1465/16 "2022-09-26T20:33:40Z")
</div>
Impossible!
Manual speed override does NOT work with DJI Fly drones.
(Mini 1, Mini SE, Mini 2, Mavic Air2, Mavic Air2s)
When cruising speed is set to zero, these drones will NOT move.
This is what you wrote in another post of yours.
> [@Waypoints: Manual increasing speed between waypoints doesn't work](https://forum.flylitchi.com/t/waypoints-manual-increasing-speed-between-waypoints-doesnt-work/645/16):
> Maybe it’s a issue of DJI FLy drones. I knew ,that they abort the mission if the sign is lost. But (I think) I remenber to change the the speed of the Mini2 using the right stick. I sold the Mini2 and can’t test this. I did a “blind” (with no sign) mission with the Mavic2Pro and it did perform different speeds at each waypoint. [[Waypoints mission with Litchi - no sign - blind flight] ](https://www.youtube.com/watch?v=l5TawhRjtJg) Choose automatic translation in your language from the esperanto subtitles. In esperanto each w…
“But (I think) I remenber to change the the speed of the Mini2 using the right stick. I sold the Mini2 and can’t test this.”
_[View the full topic](https://forum.flylitchi.com/t/cable-cam-impossible-avec-mini-2/1465)._
