I tried using the app with Avata360’s waypoint feature for the first time, but I ran into a problem. When it loses the GPS signal and position, it stops and cancels the mission. The drone was receiving a signal from 25 satellites, yet it still indicated a loss of GPS position. I’m not sure if this is a problem with the Litchi app, the new DJI firmware, or the area where I was flying (which is wide open and free of obstacles).
Thank you very much
Ricardo
When you say “the app”, I’m assuming you mean the DJI Fly app because there is no MSDK for the Avata so you would not be able to use the Litchi Pilot app.
If you truly lost the GPS signal, the drone would have lost positioning ability and would have floated with the wind. Is that what you experienced?
Loosing GPS happens in the drone. Whatever app was being used would be irrelevant. Did you receive an error message?
The flight log from the Avata would answer many questions.
Hi, thanks for your answer.
Thank you, that’s correct—it was DJI Fly (my mistake for not specifying).
I created a project in Litchi Hub (see attached image with the project settings) and set it so that if the signal was lost, the drone would continue the mission, but I assume you’re not referring to the GPS signal.
What happened was that the drone was performing a Waypoints mission and stopped at one point. The message was “No GPS signal, no position,” even though it was in an open area and had 25 satellites. DJI Fly canceled the mission, and when I tried to restart it (with GPS now available), it kept stopping due to loss of GPS signal.
Attached are screenshots of my project on Litchi Hub and an image showing the message that appeared on the RC. I’m also sharing the flight log.
Thanks
Oct-29th-2026-12-23PM-Flight-Airdata.csv (1.4 MB)
I had a look at your flight data. You launched with a strong GPS signal (gpslevel=5) and 17 satellites. You flew to a height of 38m above take-off. At 2:26 into the flight, the gpslevel dropped to 2 (poor) despite being connected to 29 satellites. At 3:15 the gpslevel went back to 5 (good) with 30 satellites. The same reduction of gpslevel occurred several more times during the flight. At 7:46 the gpslevel dropped to 0 despite being connected to 22 satellites. It did recover to gpslevel=5 at 8:26 while you were bringing your drone back to the launch point.
I can’t explain why this was happening. You were in an open area with a clear view of the sky according to what I see in Google Earth. It is possible (although unlikely) that the 20-30 satellites you were connected to did not have a favorable spread across the sky. It is also possible that there is a problem with the GPS receiver in the drone.
You had mentioned that your mission was set to continue upon signal loss. The signal that this option is referring to is the signal between the controller and the drone. It has nothing to do with the positioning GPS signal received by the drone.
Sorry, I cannot provide a definitive reason why this happened. I would monitory flights carefully until you can confirm that it was a one-time occurrence.
I have the DJI Avata 360 and dji rc2 pro and the option to continue on signal lost is not there
only hover land or return home.
The availability of the “continue” option is dependent on what country you are in.
Ha I see am in uk does work on my dji rc 2 but its got the drone tweaks FCC Mod maybe that’s why.
ok thanks for letting me know.
