# Adjust Yaw rotation speed and smothness in wp missions with user controlled heading
**URL:** <https://forum.flylitchi.com/t/adjust-yaw-rotation-speed-and-smothness-in-wp-missions-with-user-controlled-heading/2192>\
**Category:** Ideas & Suggestions\
**Created:** [March 16, 2022, 4:31pm UTC](https://forum.flylitchi.com/t/adjust-yaw-rotation-speed-and-smothness-in-wp-missions-with-user-controlled-heading/2192 "2022-03-16T16:31:14Z")\
**Posts on this page:** 1\
**Showing post:** 45
<div class="post-metadata">
**Author:** ![wesbarris](https://forum.flylitchi.com/user_avatar/forum.flylitchi.com/wesbarris/32/1817_2.png) [@wesbarris](https://forum.flylitchi.com/u/wesbarris)\
**Post date:** [April 4, 2022, 7:16pm UTC](https://forum.flylitchi.com/t/adjust-yaw-rotation-speed-and-smothness-in-wp-missions-with-user-controlled-heading/2192/45 "2022-04-04T19:16:34Z")
</div>
I have performed a number of experiments using Litchi and an Air 2s trying to obtain a smooth yaw movement as the drone proceeds through its mission. The first was a mission with a reasonable number of waypoints, one POI and the curve size set to 1/2 the distance between waypoints which results in a perfectly smooth circle:
 ![junk](https://forum.flylitchi.com/uploads/default/original/1X/435fb81b44624600830d2323c3c97681d9c25835.jpeg)
As you might have guessed, this did not result an a smooth yaw movement.
Next, I tried a similar mission with many waypoints. I got the same result:
 ![Capture](https://forum.flylitchi.com/uploads/default/original/1X/0e8b04c96bf650a0fe21167ef8af655aa5a0a24c.jpeg)
Third, I removing the curved turns, using straight paths between each waypoint. Unfortunately, I experienced the same result.
All missions were flown at a slow 5 mph. If there is a way to smooth the yaw movement, I have not yet found it.
Again, with my M2Z (on-board waypoints), the yaw movement is perfectly smooth.
_[View the full topic](https://forum.flylitchi.com/t/adjust-yaw-rotation-speed-and-smothness-in-wp-missions-with-user-controlled-heading/2192)._
